| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 8 Junior Member | | Junior Member Joined: Sep 2004 Posts: 8 | Hey Guys,
I have a '45 1 1/2 ton, left fender is hopelessly bashed in and right is about 90% good.. my question is, can I put 1/2 ton fiberglass fenders on it( I will have 16" tires on it)or is the hood longer than the 1/2 tons?...just in the research mode now, what info I can get will help me determine what I want to do with her! Rod or resto? Thanks, Bruce | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Welcome aboard Bruce The hood on a 41-46 1 1/2 ton is the same length as the 1/2 ton. The fenders will interchange and the 1/2 ton fender on the 1 1/2 ton should not be a problem with 16 inch wheels, although I've never done such a thing. | | | | | Joined: Mar 2004 Posts: 49 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 49 | Hi , You can change to the 1/2 fenders ,you will have to use both left and right you will also have to use 1/2 ton running boards as they are shorter from the rockers to the step. Hope this helps . Send me an email i might be able to help you with parts. | | | | | Joined: Sep 2004 Posts: 8 Junior Member | | Junior Member Joined: Sep 2004 Posts: 8 | Hey Guys, Thanks for the quick replies to my post!!! This is WHY the Stovebolt Page is the best source of information on these fantastic old trucks!....My wife and I bought a '52 3/4 ton while on our honeymoon in 1988...sadly we had to sell it because of my career in the U.S.Navy had us moving all over the place. I retired on 31 Dec '03 soooooo THIS ONE STAYS!!! Thanks Guys!!
Bruce | | |
