1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
I can't get my swing out windshield to seat right onto the cab when closed. I bought and installed a new rubber seal. The lower passenger piller has almost a 1/8" gap. Can't seam to adjust it out. I'm tempted to put in a narrow strip of self stick sponge rubber seal onto the cab. Would that suck? Any one else have the same problem as me?
It may not fit because the 2 bars that hold the center of the windshield frame are bent. Try taking the screws loose and fitting the frame to the cab before tightning them again. Mine had the original square bars,in the center, that I was able to remove without bending. My frame fit fine with a new rubber.
I have never done one of these windows but using just normal door adjustment thinking, can I throw you a few ideas?
If the right passenger lower corner is out away from the mating area too much, you need to bring out the top of the drivers side. Again, just using door basics. The center has only the arms from the regulator holding it in the center right? If this is the case then it "pivots" on that center in the bottom.
If you bring out the top left, it will pivot on the center bottom and bring in the right bottom.
However, if you put the frame EXACTLY where it was before changing the rubber, then you have a binding problem of some sort where the rubber is holding the frame out. This would probably be happening up on the piller on that passenger side or towards the center of the bottom. That is something you can look into.
To check if the rubber is sealing too tight or not tight enough, you can close the window down on a sheet of paper. This paper should probably be able to be pulled out without a real lot of resistance. I would think, again I have never done one of these windshields.
Have fun wink
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Are the hinges at the top the the window free to move easily? Often they sieze up, the window may seem to crank normally but can't close properly.Disconnect the window frame from the tounge on the crank, it should move in and out by hand with little effort.
Thanks for the ideas, I'm gonna check it out today. john.
