2 members (Ponchogl, Gdads51),
98
Mod | | | Forums66 Topics128,128 Posts1,056,670 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | Has anybody put seat belts in their 48-54 truck? Lap belts would be easy, but, I want to add the shoulder strap as well. What would they attach to???? ken | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Deve, wrote what I'd consider the book on the subject, it can be found here. I did mine similar to what he did with a few modifications. That can be found here. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Aww, I dont care what anyone else says about you guys! LOL! Yeah, do it right when it comes to the 3 point system and be sure to beef things up for safety.
Also, I like the idea of a bracket that comes up from the floor at the back edge of the seat pedestal and rises up to meet at about the seat bottom/seat back intersection rather than what I did and just bolted to the floor. Thanks to everyone who took my idea and ran with it. We all learn more that way!
So rather than just the hole in the floor coming up thru to the back of the seat pedestal, do that without modification, but then, make a bracket out of about 10 gauge steel that follows the seat pedestal back and has another weld nut on it at about the height of the seat intersection to bolt the belts to. Spot weld this bracket to the pedestal so it cant move. Happy to describe this better if you need. Its just another way of doing it, and it could be better in the long run, but I havent really assessed the difference myself. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | A little off topic, and this guy was very lucky, but if he would have used Deve's method, he would have had a much smoother ride. Bad Seatbelt Installation
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | That hurt just watching it. If you are drag racing, you need the 4 point harness and no messing around with inferior methods. I feel that way with my projects. Safety just isnt up for grabs. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Deluxe cab?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I think a key point to remember is that Deve's installation is done on a restored cab. Don't assume belts will hold safely if you are installing belts into a well used and rusty truck without first examining the floor pans where the belts will tie in. The floors ARE NOT that strong by themselves.
Drew
| | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | Thanks guys for the input and especially the videos. Using Deves guide i have the driver side installed and the passenger and center will get put in today. The 48 has the gas tank under the bed so with no gas tank behind the seat it was a bit easier. I am using a set of belts "stolen" from a '91 Astro van. Each bolt thru sheet metal, whether floor or sides or riser, has a 10 gauge piece as backup - dont want those things pulling out. Maybe some day I will figure out how to post pictures as links on this site. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I'm planning to install the same Juliano's belt set in the 48 2 ton. What length lap belt did you use for the middle position? | | |
