4 members (Millenimech, UtahYork, mason86, delky), 59 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#857879 06/10/2012 6:50 AM
Hey guys, just wondering if the Chevy 235s are an interference engine or not. Some people I've talked to about my engine issue think that one of my valves may b=have gotten stuck and the piston hit it, bending it. Sound likely? I assumed they were non interference but maybe I'm wrong.
PS, doing a compression test tomorrow or the next day, should give me some more clues.
I have never had that happen to me. I have had a couple of 235s that a valve stuck on them. Once freed up they were fine. I think the valves are to far up in the chamber to be of very much riskl of a piston hitting them.
But some one may know more about that and tell us.
Ex Hall Monitor
Ex Hall Monitor
The only sticking valves I've heard of stick shut & bend pushrods rather than stick open. I don't know if one stuck open will strike a piston or not. Now I curious. Anyone know?
With the layout of the valves in the head, it would be impossible to get valve/piston contact. The only valves that get remotely close to the piston also overhangs the block. It would hit the top of the block before it could reach the piston.
The intake valve is directly above the piston at TDC, with very little safety margin. If the valve sticks in the guide, since the valve is nearly vertical the piston may just push it back. If not, the valve bends or punctures the piston dome.
The exhaust valve can't hit.
I am with Panic on this.
My Blog
Sorry, realize this is an old thread, but thought I'd contribute if anyone else is curious.
I floated an intake valve (over-revving the motor) and can confirm it WILL hit the piston, resulting in much carnage.
