0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1061335 10/10/2014 12:35 AM
Would a small shop vac provide enough vacuum to test a wiper motor? Someone has suggested 20 inches of vacuum, but I have no way to measure that.
BobS46
BobS46 #1061338 10/10/2014 12:44 AM
Not trying to sound silly but you could suck on it.
BTW Mine (from Arizona) had been in the truck since new, I just sent it out to the fellow (wiperman) in NY who rebuilt it and it works perfectly. A great deal for a little over $100 IMO
1955 First Series 3100
Do you have a vehicle that runs? Hook it up to a vacuum port on any engine to test it. May need a long hose if the wiper motor is still in the truck.
Carl
I used our central vac and it gave about 11 inches, if I remember correctly. I found it very handy for working on the bench.
1951 1 Ton Completed
Carefully dismantle and clean it...lube inside Wiper edges and Die-cast inside Body trough with a nice light coating of Vaseline...re-assemble, then 'test'...
