2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | Does anyone know of a Power Steering Conversion kit for a 1941 Chevy 1/2 ton pickup with a 216 engine? Or maybe a way to make the steering easier?
Wayne
Wayne Selway
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Wayne, Contact ABS in Orange. 714-771-6549 www.abspowerbrake.com.They can offer you some guidance. I have used a number of their brake & steering kits for many years. I have not done a 41 however. They will also likely be at the LB swap meet this weekend. Fred
| | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | I will give them a call. WOW I forgot about the swap meet.
Thanks Again Wayne
Wayne Selway
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The steering should be easy in the stock form. The steering components may be worn, damaged, or out of adjustment. Non-stock tires may also make steering difficult. I have let a number of people in poor physical condition drive my pickup and non had any issue with the steering. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The steering should be easy in the stock form. I agree. 1941 was the first year for the reciprocating ball steering box design that was used from then on. If the box is in good shape and full of oil it should steer quite easy. Of course fat tires will have a negative affect on this.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The stock steering is, in theory, just about the best type of steering box you can get. It may need to be rebuilt and even if it doesn't, a good idea would be to check it and be sure the bearings and bushing are in good condition. These boxes are easy to rebuild and if you can adjust them out before you reinstall it in the truck, you should have just about the best you can have.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
