4 members (Joe H, baldeagle, panic, 1 invisible),
74
Mod | | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 1954 235 z TDC question
This may sound elementary If my pointer is on the ball and rotor pointing to number 1 wire and both my pushrods are loose on # 1
Would that mean that #1 is on the compression stroke.
Or does that happen again in the cycle?
Second Last time I did a compression check I only removed the spark plug on the cylinder I was testing. Is that correct or should I have them all removed ?
Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If my pointer is on the ball and rotor pointing to number 1 wire and both my pushrods are loose on # 1
Would that mean that #1 is on the compression stroke. Yes - regarding compression stroke (move flywheel/crankshaft until both push rods are loose) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Last time I did a compression check I only removed the spark plug on the cylinder I was testing. Is that correct or should I have them all removed ? This procedure looks OK: "Disconnect the main wire to the coil and spark plug wires; remove spark plugs." Remove all spark plugs - 1954 Truck Shop Manual | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | I guess "plugs in" would work for compression issues related to rings or valve seating (cylinder specific issues), but might not be so good at accurately diagnosing bad head gasket/ cracked head (compression loss between two cylinders).
Am I thinking of that correctly?
1951 3100
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | This shows the 4 stroke engine. Intake, compression, combustion and exhaust. This should help you identify where your at when bringing an engine to TDC for installing a distributor. http://en.wikipedia.org/wiki/Four-stroke_engine | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Remember the ball is not actually tdc. It should be 5deg before with all the info I have found over the years. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Remember the ball is not actually tdc. It should be 5deg before with all the info I have found over the years. That is correct for most year flywheels, but the timing mark could be before or after TDC depending on year and engine (216/235/261) flywheel. To complicate this, people often changed flywheels for various reasons. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yes I'm not referring to true TDC But for starting and timing purposes.
Thanks for the information
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Remember the ball is not actually tdc. It should be 5deg before with all the info I have found over the years. That is correct for most year flywheels, but the timing mark could be before or after TDC depending on year and engine (216/235/261) flywheel. To complicate this, people often changed flywheels for various reasons. My head just exploded. Can I at least assume that the timing mark is close enough to TDC for initial timing/ startup purposes? Or can the mark be way off and meaningless if the flywheel was replaced?
1951 3100
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | If the wrong or different flywheel is used on another engine setting the timing to the ball can cause a black hole..... everything as we know it will end.
The ball mark will get the engine running fine. Then adjust from there after your running. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As wolffcub posted, any timing mark/ball will get you close enough to get it started.
After getting the carburetor adjusted to idle speed, I use a vacuum gauge to adjust timing and carburetor mixture to obtain maximum vacuum reading.
