5 members (klhansen, Otto Skorzeny, Wayne67vert, Frank50, TrknGMC), 67 guests, and 4 robots.
Topics128,077
Posts1,056,012
Members48,433
#1059752 10/02/2014 1:01 PM
I am missing these braces, and will be fabbing something up. Its clear where they mount to the fender, but do they mount to the bottom of the frame then? Can I get a pic, please. Thanks
What year and model of truck?
Sorry, '49 3600
That's a different story. Now that we know what model your have,
here's a '50, 3604 right rear fender brace, which bolts to the
top of the frame:
http://www.pbase.com/dennygraham/image/157698438/large
dg
Denny G
Sandwich, IL
I've got a set of rear fender braces for a '49 3100. Don't know if they are the same, but you a welcome to them. The rear fender braces on the 3100 mount to the bottom of the fenders and to the bottom of the frame. Just PM me with your address and I will send them to you.
Tim
1970 VW Beetle
The 3100 frame is wider than the 3600 Tim. Also being mounted
under the frame would make them even that much more short.
dg
Denny G
Sandwich, IL
No big deal to make one up. Pickup a length of 3/8" round
stock from any big box or farm store, enough to give you
a 19" length. Heat up the end with a torch, even Mapp gas
will do that, and flatten them out for about an inch. Punch
a hole thru each end, that's it, nothing special.
dg
Denny G
Sandwich, IL
Thanks again for the pic, Denny.
Tim, thanks for the offer though.
One of my fenders had a bracket still mounted, But apparently its a 3100 fender. Which is what was confusing because I couldn't cipher where it attached to the frame, too short.
I plan to make some up soon. After attaching my running boards yesterday, that really seemed to stiffen up the fenders a bit.
Tim,
As it happens I am also in need of rear fender braces, for a 51 3100.
Is the offer still open?
(Sorry, would have PM'd but don't know how yet)
Marc
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Left click his handle and select Send a PM. If you see
that make sure you are logged in.
dg
Denny G
Sandwich, IL
