0 members (), 113 guests, and 2 robots.
Topics128,101
Posts1,056,180
Members48,436
I changed to 12 volt system, and used a runtz voltage reducer on the gas gauge. Should I be using a 6 volt or a 12 volt sending unit on the tank? Currently I have a 30 ohms sending unit in there and I bench tested it and it is working fine, but the gauge is still not reading. Grounds seem to be good at the tank and gauge. The truck is a 53 Chevy with a 54 - 235.
Thanks in advance.
sending units are just variable resistors, they care not about voltage .... a zero to 30 ohm sender is what you should have for an original gauge, so the most likely problem is the gauge itself, unless you have the Runtz wired wrong or a defective one
Thanks Bill
