| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | This past weekend at Carlisle I acquired a set of NOS directional fender/chassis lights for 1958 through 1966 C10. Upon inspection just yesterday I found one with a disconnected bulb wire. They are single wire. It appears that the wire is simply snugged through a turn of the small contact spring for the bulb. I thought that odd. But anyway, I don't see a problem with soldering the wire to the spring. Any other advice is appreciated. I know Deve has NOS, so hope you chime in Deve. Thanks guys.
Drew
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look into one of the other sockets - there should be a "nub" soldered to the end of the wire that contacts the solder button on the base of the bulb, that nub sits in a hole in a round fiber/plastic piece that fits on top the spring, you do not want the wire to contact the spring, which will be ground
Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Okay. Thanks. I have the fiber ring, but not the nub. I'll check the original box really well to see if it's under a flap. Can I buy a nub at Radio Shack or ? in case I need a replacement?
Drew
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doubt you'll find the metal contact alone anyplace, but any FLAPS should have pigtails like this that you can use to effect a repair Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks greatly. That will be perfect. All kinds of goodies in the box with a 4 page fold out on mounting and wire diagram to install these lights, but no words or pictures on the bulb and wire. So, thanks again.
Drew
| | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | DrewP, In the past, I've purchased those wire end contacts from YnZ in Relands, CA. The contacts are 0.25 each, unfortunately they have a $20 minimum order. If you need some other wire related things, they might work for you. http://www.ynzyesterdaysparts.com/pdfs/p1_Electrical_Terminals.pdfBob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Actually, I went with this outfit. www.delcity.net The contacts were 62 cents apiece, for 1 to a 100.
Drew
