0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 36 | I am missing these braces, and will be fabbing something up. Its clear where they mount to the fender, but do they mount to the bottom of the frame then? Can I get a pic, please. Thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | What year and model of truck? | | | | | Joined: Dec 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 36 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's a different story. Now that we know what model your have, here's a '50, 3604 right rear fender brace, which bolts to the top of the frame: http://www.pbase.com/dennygraham/image/157698438/largedg
Denny G Sandwich, IL
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I've got a set of rear fender braces for a '49 3100. Don't know if they are the same, but you a welcome to them. The rear fender braces on the 3100 mount to the bottom of the fenders and to the bottom of the frame. Just PM me with your address and I will send them to you.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The 3100 frame is wider than the 3600 Tim. Also being mounted under the frame would make them even that much more short. dg
No big deal to make one up. Pickup a length of 3/8" round stock from any big box or farm store, enough to give you a 19" length. Heat up the end with a torch, even Mapp gas will do that, and flatten them out for about an inch. Punch a hole thru each end, that's it, nothing special. dg
| | | | | Joined: Dec 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 36 | Thanks again for the pic, Denny.
Tim, thanks for the offer though.
One of my fenders had a bracket still mounted, But apparently its a 3100 fender. Which is what was confusing because I couldn't cipher where it attached to the frame, too short.
I plan to make some up soon. After attaching my running boards yesterday, that really seemed to stiffen up the fenders a bit. | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | Tim, As it happens I am also in need of rear fender braces, for a 51 3100. Is the offer still open? (Sorry, would have PM'd but don't know how yet) Marc | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Left click his handle and select Send a PM. If you see that make sure you are logged in. dg
