6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#1060026 10/03/2014 10:15 PM
Anyone know what GM rear will swap with the 48 1/2 ton Chevy pickup torque tube rear?
If the dash ain't steel, it ain't real!
Going 65 #1060030 10/03/2014 10:49 PM
Are you staying torque tube?
If so 1948-54. 1954 will be a 3.9 ratio instead of 4.11
My Blog
Going 65 #1060066 10/04/2014 2:26 AM
A 3.55 ring and pinion gears can be swapped for the 4.11 gears.
Going 65 #1060080 10/04/2014 3:30 AM
Not staying torque tube. I want an open drive line.
Going 65 #1060136 10/04/2014 1:06 PM
the 55-59 should be bolt in swap (other that switching to open drive). Someone will correct me if I am wrong though
Going 65 #1060160 10/04/2014 3:10 PM
i used a chevelle el camino on my friends ad 73-77 then redrilled the axles to six lug
Going 65 #1060189 10/04/2014 4:24 PM
I hate to (have to) say this, but do a search. There is enough info on rear end swaps on this forum to keep you busy reading for a month.
Going 65 #1060201 10/04/2014 4:52 PM
If you can find a first edition 55 AD style truck. the rear end with the springs it is an open rear end and will bolt in.
Tommy
59 apache 1/2t
261 short stepside
GMJager #1060273 10/05/2014 1:27 AM
That is correct, but you would not necessarily have to swap the entire rear, only the third member would be needed to get open drive and 3.90 gears. The pivots would need to welded up as well. Coupled with an overdrive transmission, the 3.90 gear is a great all around ratio.
Bill Burmeister
Going 65 #1060299 10/05/2014 2:38 AM
If you swap a 55-59 axle on a set of 54 and earlier springs, will the axle be located in the stock position (forward of center of wheelwell)?
Going 65 #1060301 10/05/2014 2:43 AM
Since swapping the entire housing would require installing new spring pads to the housing ('55-'59 is spring over axle, rather than spring under like the '47-'54), you could easily set it up to sit where you want it. The center section swap would keep it in the stock location, as the housing itself is not changed.
Bill Burmeister
LONGBOX55 #1060367 10/05/2014 2:09 PM
Thanks for including that LONGBOX. the center section of the 55-59 will swap, and the pivot points on the axle housing would need welded up. Or as someone else mentioned... the 55.1 rear end is a complete swap in. Thats what I did.
I had to drill new holes in my spring perch pads to relocate the rear exle to the center of the wheel well
LONGBOX55 #1060743 10/07/2014 1:24 AM
Thanks Bill. I wasn't aware of the spring-over-axle on the 55-59.
Carl
