2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#1059972 10/03/2014 3:45 PM
I located a 1983 p-30 motor home chassis. These frames are supposed to be good donors for my 52 COE build.
I am a visual learner so I need pics showing the process of a similar undertaking or completion.
Anyone out there who as done this? Please send pics to my email or message me.
My donor frame is rust free, has a good steering box, disc brakes all around. I am going to move the rear end forward but have to get everything measured out with the cab mounted prior to moving the rear end.
Any help would be appreciated.
found an old post very helpful, especially Barons photobucket.
Crusing in the Passing Lane
See if the front axle will fit your COE front fenders, if so, you are in luck. If not, see Grigg's story about shortening the axle or fitting modern spindles to existing axle. The rest should be straightforward. Full disc brakes and Saginaw steering are great for today's highways. Use the power brake [censored]'y w/ the COE.
If you have specific questions, ask for a px.
