| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | The horn contact spring unit that is supposed to fit my '54 truck doesn't. It is too short. The contact spring unit is 1 3/4" long and from what I can figure out I need one that is 2 1/8" long. The cab was originally from a 3600 dually but I can't imagine that would have anything to do with this problem. Tried to jury rig it and burned up the horn. Literally. Had to pour a can of soda on it to put it out. Any suggestions? | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Wow.....there shouldn't be enough power in there to do that. Something isn't wired right. The horn wire in the steering wheel is just a ground for the horn relay. | | |
