0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
U
U Offline
Here is a picture of three Carter YF carbs I have: Carter YF 2100S, YF 2100S, and YF 938SD . The one pictured on the right is the 938SD and it has a tube above the choke plate/valve. It was rebuilt in '96 by someone who would put a 'certified rebuilt' tracking number sticker on one.
The two carbs on the left are YF 2100S models that I am cleaning to use on a 55.2 235(single carb application; I recently found a spare carb). They do not have the tube above the choke plate/valve.
Am I missing this tube on both of my YF 2100s? Or is this their design? I noticed my Rochesters also have the tube.
Brad
Last edited by ClaudeTheTruck; 10/02/2014 9:44 PM. Reason: changed "part" to "this tube"
Wrench Fetcher, PhD
I think that is the vent tube from the float bowel. It helps keep the air pressure in the float bowel at or just under ambient. So the float can do its' job. Check with Carb King to see if I am right. You could make one up but how to secure it would be the trick.
Steve H
U
U Offline
I won't reveal my source so I don't butcher his terminology, but the Carter YF 2100S carburetors do not have the tube in the air horn that I was questioning. This is based on a later model Carter YF.
So, if anyone finds this post with the same question I had- the YF 2100S does not have the angled tube in the air horn.
Brad
Wrench Fetcher, PhD
