1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 4 New Guy | | New Guy Joined: Aug 2014 Posts: 4 | I have a 1949 GMC 3/4 ton long bed and would like to change the rear end gears. I now have 456 gears. If anyone can help me with what I need to do to change to lower gears, I would appreciate it. Thank you. | | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I to have a 1965 GMC 3/4 t long bed and would like to change the rear end gears but I will be doing it next year I have no idea where to start looking for information hope you can find something Maybob
Bob May
| | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I went to search and typed in rear end gears there is a lot of information on rear end but not on 1965 4/3 ton
Bob May
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Papa7, what you're really looking for are higher gears. Unfortunately, there's really not much available for the Eaton rear other than the 4.10 option from the '68-'72 3/4 tons with V8/automatic. Those are starting to get hard to get due partially to the demand, but also to many of them getting used up by the dirt racers in the '70s/'80s. The only other option is to change out the entire rear for a later model with a better gear. A Dana 60 from a late '80s/'90s Ford or Dodge van, usually with 3.55 gears, is just about the right width for an AD truck. County Boy, since you have a GMC, that gets into a completely different animal than the Chevrolet. For the most part, GMC used the full float version of the Spicer (Dana) 60 in 3/4 tons. That will make things much easier for you, as the 60 is still being used to this day, mostly in vans and some 1/2 ton GM trucks. Due to the popularity in trucks as well as certain MoPar passenger cars, as well as the racing and off road communities, parts are readily available. I would suggest that you check out Randy's Ring and Pinion. You should be able to find any gear ratio you want there. Be warned, you may have to change the carrier depending on what gear you go with.
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Papa7, to put it another way, you need a lower ratio gear set. Carl
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Perhaps some clarification might be in order. When dealing with gearsets, a numerically lower ratio ,say, 4.10:1, would be considered a "higher" gear than the 4.56:1. Also, a numerically higher gearset, such as 5.13:1, would be considered a "lower" gear. So when one says that they want a "lower" gear, folks in the business may take it that you mean you want to with a numerically higher ratio. Other terms that are used in a similar manner are "tall" and "short" gears, which are high and low gears, respectively.
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Clear as mud. In which case you will need "better" gears.
