0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | Can anyone enlighten me as to which tailgate (lettering wise) is correct for a 54 GMC 1/2 ton? The one on my truck now, which appears to be original, has an elongated "M", with the G and the C on either side (hard to explain without a picture). I have seen pictures of this gate on other trucks, but have also seen the more standard "block" letters. To make matters worse, it seems like everyone that I ask has a different answer, and the catalogs seem to only have the block letter variety. Any ideas as to which is correct? If its the elongated version, would anyone happen to know of a source for them? Thanks. | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | The correct gate for the '54 is the one with the rounded GMC script letters and "elongated" M in the middle that's more rounded.
A '55-'59 gate will fit the '54 bed, but the letters are more block like. That is a one year gate basically.
'54 was the first year for the "grain tight" gate and flat top siderails. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've seen a few on eBay, and you could probably locate one through the swap meet, but they seem to be fairly expensive, as they were only used for a year and a half.
ChevyDuty has it listed in repop for $200. I don't know anything about the quality. | | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | My '54 came with the block letter tailgate but I have an original magazine ad for the '54 GMC truck that has the enlongated "M" tailgate so I believe the enlongated "M" is the actual correct one. | | |
