Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#1058489 09/25/2014 5:22 PM
My headlights are real dim and yellowish. I checked the ground and it appears good. I also bypassed the switch, but neither helped. Just wondering if anyone has any ideas.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #1058503 09/25/2014 6:30 PM
what year? which voltage? engine running or not? got the right bulbs? the positive connections are as important as the grounds, have you checked voltages with a meter?
pablos49 #1058505 09/25/2014 6:33 PM
It's a '49, but it's rodded. 12 v system, runs and drives. The lights worked good when I first wired it, but have been dim since I got in a wreck and had it repaired.
pablos49 #1058507 09/25/2014 6:44 PM
bad connection somewhere, start with cleaning them all well, especially any intermediate connections under the hood, like the plugs on the bulbs and any terminal blocks on the inner fender - also make sure you generator/regulator [or alternator] connections are all clean and tight
pablos49 #1058556 09/26/2014 12:13 AM
Have you taken a volt meter and see what the voltage is at the socket?
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
52_Ton #1058686 09/26/2014 5:00 PM
Check out this site: Mad Electrical . They have information about putting relays in for the headlights to make them brighter. Part way down you will see the heading "Brighter Headlights".
It's a small world, but I wouldn't want to paint it.
