| | | Forums66 Topics128,161 Posts1,056,957 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | Do you guys know if the front suspension spindles for the 63-66 1/2 tons are the same as the 67-70 1/2 ton spindles? I have a project in mind and if they are the same like I think they are it will make things better for me.
I did a short amount of looking and I didn't some up with this specific answer, lots of people swapping a arms etc.
Thanks for any help
Jason | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy macgyver37, I don't have a parts book for light duty trucks up to 1970, only to 1967. The steering knuckle on a 1963 is p/n 3818705, the steering knuckle on 1964 through 1967 is p/n 3860570, these numbers are for 1/2 ton C and P series, hope that helps. | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | Thanks, it is encouraging that they are the same from 64-7. The two trucks I am working on are actually 65 and 70, so I am not really concerned with the 63, I just thought they might be the same as 64-66 so I included that year. I may have to just take both apart and compare side by side.
Thanks again, Jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | |
