| | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | My headlights are real dim and yellowish. I checked the ground and it appears good. I also bypassed the switch, but neither helped. Just wondering if anyone has any ideas.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year? which voltage? engine running or not? got the right bulbs? the positive connections are as important as the grounds, have you checked voltages with a meter?
Bill | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | It's a '49, but it's rodded. 12 v system, runs and drives. The lights worked good when I first wired it, but have been dim since I got in a wreck and had it repaired.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | bad connection somewhere, start with cleaning them all well, especially any intermediate connections under the hood, like the plugs on the bulbs and any terminal blocks on the inner fender - also make sure you generator/regulator [or alternator] connections are all clean and tight
Bill | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Have you taken a volt meter and see what the voltage is at the socket?
Mark | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Check out this site: Mad Electrical . They have information about putting relays in for the headlights to make them brighter. Part way down you will see the heading "Brighter Headlights".
It's a small world, but I wouldn't want to paint it.
