| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | guysand gals,i want to install a292 in my 55 panal.so far I have been unable to find motor mounts.ist question would it be possible to used the mounts like the 216 that was in it before?there is four 3/8 threaded holes on the front.give me some ideas please.also the 292 is 3-4 inchs longer than the216.which means I will haved to cut a notch for the damper.would this weaken the front cross member? thanks again. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | why not just use the side motor mounts on the 292 and brackets bolted to the frame rails. I did this on my 61 and it worked out nicely
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | I should have mention my panel is second series,the frame rail are about 16 inchs wider than a 66 or later years.have the stock brakets,do,nt work,,,, | | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | 292's bolt into anything that a small block will fit into, you should be able to use any of the small or big block conversion brackets. I really doubt anybody makes a bolt in kit, so you are just going to have make due.
Front mount will work as long as you you use side mounts on the transmission. You must three points of contact or it will just twist and lay over.
Cut the front crossmember to clear, then add a new one back under the motor to support the engine like its suppose to be. 2"x3" tubing is not that expensive and makes nice looking cross members.
Joe | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Joe, Tom Langdon did. I have a set, but unfortunately he doesn't sell them anymore and says to check with CPP. But, I don't see them on their site. I think John will just have to create his own to fit from pieces/parts.
Drew
