1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
7
7 Offline
I am asking members if upon final assembly of my truck. Would they put the front tin onto frame a piece at a time, or would they assemble the entire front clip on ground and put it onto truck as a entire assembly ?
Any info would help.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
Initially, my thoughts were a piece at a time, but as I am doing fender body work now, both off, I found as per more experienced advice that removing the front clip is best and reassembly as a clip too. The guidelines are in the shop manual.
Drew
Assembly as a complete clip on many models is easier provided you have adequate help the day of installation. If you are a one man show, you may be forced to assemble one piece at a time. I have used shipping packing material temporarily taped to contact points to avoid scratching things up.
Lots more pictures
What year truck?
How well do you trust your help to keep from gouging the new paint?
7
7 Offline
Its a 1950 5 window 3100.
My help would be working under the threat of bodily harm if things got scratched up. :)
All Original
I did it piecemeal on my '52 basically in the following order (no help needed):
Radiator/core support
Inner fenders
Fenders
Bottom splash shield (or whatever it is called).
Grille
Radiator shroud
Hood.
Followed by lots of adjusting of mostly core support (shimming up) and hood hinges.
I did it one piece at a time, but had no help. It wasn't too bad.
I pretty much followed DavidF's order. The only really tough area I recall is the fender to inner fender to radiator frame.
I had an ample supply of those ...what do you call them? "Dog-tailed" bolts or screws. Or something like that. They're tapered. They really made the initial threading in a lot easier!
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
