| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Howdy; I've read the 6 page thread on Dynamat and the other sound deadeners, and watched a number of you-tube videos on the topic but I'm wondering if anyone has had any personal experience with using any of them on the ceiling of their cab, or whether they've used something else successfully. That some of the deadeners come off easily when heated concerns me that a day in the hot sun might cause them to sag. Suggestions?
Thanks - Bruce | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I 3M contacted cemented two layers of foil cover bubble wrap. Held up fine through the summer heat. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | One layer of single-foil-side bubble wrap (foil side up): attached with 3M Super 77 Multipurpose Spray Adhesive over 10 years ago. It is holding up fine.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I used a rollon contact cement but I have used the 3m spray adhesive and it worked too. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I only wanted to do this once (installing the headliner) and so spent the $$ on Fatmat. It was easy to install and appears to have adhered well. Time will tell of course. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I used the Reflectex (Home Depot, 50 beans maybe) foil bubble both sides with the 3M 77 Adhesive also. I used on the roof,doors and under firewall. Seems to still be adhered
Dan | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | sounds like the foil lined bubble-wrap may be the way to go for those of us on a budget. Thanks for the advice!
BV | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Has anyone taken note on how well the silver bubble wrap insulation reflex heat? I was planning on using this myself.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Here's a quick before and after showing the difference made by a piece of Eastwoods Thermo coustic on my cab. I costs about have that of Dynamat. I painted the cab ceiling first to give a clean surface to stick to. It's been there for about five years now. I've used it all over the inside of my cab. I hope I never have to remove any because it STICKS! | | |
