6 members (cmayna, Hugh63c10, Cosmo, TUTS 59, oldieoldie, greenie-reddy), 128 guests, and 4 robots.
Topics128,184
Posts1,057,195
Members48,465
Here are the approx specs:
8 bolt holes, 0.500" in diameter each
Approx. 4.700" outside diameter
Approx 2.900 - 3.100" inside diameter
I cannot find any current part number anywhere. These are the thick metal gaskets (or tins) that go between the axle shaft flange and the wheel hub.
I was able to find a modern DANA gasket that I modified, but it is too thin and leaking.
1946 Chevy 2-Ton Rat Rod Wrecker
I have made a new development.
I believe the GM part number is 3653928. Although that still hasn't gotten me anywhere.
I haven't used a flange gasket in years. I use silicon and it works better than gaskets ever did. The OEMs have not used gaskets in over 30 years.
I bought mine at Jones Vintage parts. They are a little slow in checking stock. Ask for Seal 5904s and ask them to take measurements
As above. I made mine from 0.5mm or .020 gasket paper and then used rtv. No problems at all.
'47 Canadian RHD 1.5 ton truck
