1 members (Bill Hanlon),
156
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Here is another of my "basics" in auto body. Hope it can be of help so someone. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>Paint technology basics
There are many different types (or more correctly, technologies) of products you can use in the restoration or repair of your vehicle. Some have a variety of uses while others are very limited with only a few of specific uses. Proper choice of products can help you get the job done faster and/or help with the longevity of the repair. Let's start with some basic definitions. I couldn't possibly know every paint manufactures terminology or product use. These are generalities and should be used as a guide only to then read the tech sheets of the products you are choose for proper use. These tech sheets can be found at the jobber and are given away free. Or most manufactures have them on line, USE THEM. They are a wealth of information and can save you many headaches. You don't need to read every word in the mind numbing text, they usually have a “product at a glance” or something like that will cut to the chase and give you what you need.
Basic terminologies;
“Solvent” is a generic term and refers to any “reducer”, “thinner” that is used to reduce the viscosity (“thickness”) of a product to aid in spraying or applying. It could be acetone, lacquer thinner, urethane reducer, a special “basecoat” reducer, water, alcohol, etc. These solvents ARE NOT INTERCHANGEABLE; each product MUST be used with the specific solvent recommended by the manufacture. “Etch primer” an acid containing primer. “Primer” a product that can be applied to bare metal “Surfacer” (or “primer surfacer”) A primer that has “body” or solids and is used to fill imperfections and provide a film thickness to sand or block a surface to a smooth base for paint. “Sealer” a non-sanding product that is applied prior to painting. “Primer-sealer” A sealer that can be applied over bare metal and then top coated without sanding. “Flash time” the time you allow the solvents to evaporate out of the film you have applied.
Basic technologies; “Single component” or RTS (Ready To Spray). This is a product that uses no additional components. Just pour it from the can into your gun and shoot. Examples are: Some plastic adhesion promoters and primers and even some top coats like vinyl colors.
“1K” This is a product that uses no hardener, catalyst, activator, etc. It may have an added solvent, but no hardener or activating reducer. 1K products like RTS dry with the evaporation of solvents and are soluble, meaning that they are could be wiped off with a rag soaked with lacquer thinner. They could in THEORY be scraped off and put in a can with solvent and stirred back to a sprayable condition. Of course ALL RTS products are 1K. Examples: All lacquer products, some synthetic enamel products, and some acrylic enamel products. Because of the low VOC regulations the 1K product options are getting scarce, with most limited to “specialty products” like adhesion promoters.
“2K” or “Two component” is any product that uses a hardener, activator, catalyst, etc. It may or may not use a third component in the form of a solvent. 2K products don't “dry” like a 1K. The 2K product “cures” by molecules linking together to form a whole new compound. Most high quality 2Ks are insoluble after a full cure and will not soften when exposed to solvents like thinners or gas. Examples are urethane under coats and top coats. Epoxies, ISO free products that use a hardener, etc.
Basic tip, ALL 2K products should be mixed as accurately as possible. As a rule 2K products need a minimum of 55 degrees to cure with an ideal minimum of 65 degrees. MIX THEM AS DESCRIBED BY THE MANUFACTURE. They have spent hundreds of thousands, possibly millions of dollars developing the product, they WANT it to work as BEST it can. Do as they say, don't become a “Junior Chemist”.
Types of products and their uses;
Etch primers (some are 2K)
“Wash” or “Vinyl wash” are for bare metal applications for the ultimate in adhesion and corrosion protection. They are very low in solids with next to zero filling qualities. Some are even semi transparent. They are usually not to be top coated with paint. You apply them to aid in adhesion and corrosion protection under other undercoats such as epoxy or urethane primers. Benefits: - Very thin, keeps down film build - Cost effective - Fast application - Non-sanding - Super high corrosion protection.
Disadvantages: - Some have a very small re-coat window
“Etch primer” (some are 2K)
Typical “etch primers” have much more solids and body than “wash” primers. They are more forgiving than “wash” primers, one thing being a much longer re-coat window. They are basically used to aid in adhesion and corrosion protection as with “wash” primer. You would choose “typical” etch over “wash” if you have some paint or plastic filler as a substrate along with the bare metal. Some brands have a recommendation to apply top coats over it also. This could be very useful in a money saving or time saving is important.
Benefits: - Easy to apply, smooth, easy to sand - Some can be applied over plastic filler (not that you need it over the plastic filler, but if you have some, it is nice to not have to go around it) - Some can be top coated, which can be a big time and money saver. - VERY cost effective
Disadvantages: - Added product to buy and apply.
IMPORTANT basic! If you have used ANY metal treatment or “conditioner” read tech sheets carefully for compatibility . The acid in the metal “treatment” or “conditioner” can attack the acid in etch primers and it can LOOSE adhesion from the metal!
Urethane primer (2K) Urethane primer is the most common primer used in auto body and restoration by far. It has good solids and fills well. It is easy to sand and can provide you with a perfect body when blocked properly. Care should be taken when applying it as to not use too much. It can shrink when applied too heavy. It is the best all around primer for applying over plastic body filler and for surfacing your work. If used properly it provides the proper film thickness under top coats and is the perfect substrate for bs/ss and SS.
Benefits: - Easy to apply, and sand. - Applies smooth. - Fills well with minimum of shrinkage
Disadvantages: - Contains Isocyanates. - Should always use an etch primer under it.
Epoxy primer (2K)
Epoxy is a good corrosion fighter. It is has a very sticky resin and will provide good adhesion to MOST substrates. It typically has poor filling and sanding qualities (that sticky resin makes sanding difficult) . It is ideal for use as a “primer/sealer” on bare metal that requires no surfacing. Perfect for frames and components, radiator supports, items that are sandblasted and you only need to prime and paint. You use it as a non-sanding “primer/sealer” and then paint right over it.
Benefits: - Good chip resistance (it isn't as hard as a urethane) - Perfect for a “primer/sealer” over bare metal. - Etch primers can skipped because of its excellent adhesion and corrosion properties. (although for maximum corrosion protection apply a wash etch under the epoxy) - Provides good base under plastic body fillers (skip the etch if you plan on using plastic filler over epoxy) - Epoxy has no isocyanates .
Disadvantages: - Poor sanding qualities - Poor filling
Polyester primer (2K)
Polyester is a very specialized primer used in very small amount in most shops across the country. But when it is needed, it does a job like no other. Polyester has a huge solids content and will fill 80 grit scratches in one coat or 36 grit in two or three! Urethane for instance provides about ½ or ¾ mils per coat while polyester can give you as much as 4 to 6! Because of it's high solids, it shrinks very little. It is basically like spraying polyester putty. Look for a manufacture that has a recommendation to apply etch primer under it. I see NO reason to use polyester on a straight panel. It is for use only when you need some serious filling and surfacing.
Benefits: - VERY high filling - Low cost
Disadvantages: - Very high texture - Harder to sand than a urethane - Possible need to purchase a large gun to shoot it. “ISO FREE” (2K)
“ISO FREE” is a urethane type primer but without the harmful isocyanates that a urethane contains. The problem is ALL refinish products should be used with the same care and concern for your health and others. ISO FREE is like “low tar” cigarettes, don't kid your self, it is still VARY harmful.
Benefits: - Isocyanate free - Smooth, easy sanding - Good filling Disadvantages: - You need an etch over bare metal before it.
Basic tips… Etch primers can be skipped on spots of bare metal smaller than a dime or so when using all primers listed. Most “quality” 2K primers need NO sealer before top coating with bc/cc or SS when applied properly.
Sealers
All RTS or 1K sealers should be reserved to VERY low end jobs to save money. They do NOT offer the benefits of a 2k, PERIOD.
Reasons to use a sealer:
- Makes up for “some” poor preparation - Provides a uniform color for better coverage when you apply paint. - Helps with providing a uniform substrate for paint. - Helps provide a better substrate when painting over a 1K primer. - Can Help with “covering” poor prior repairs
Under collision repair conditions a shop may use sealers on every job as an “insurance” protection against problems. In a restoration environment where complete panels are primed with a 2K there really is no need to use them. If you have chosen to use a sealer there now are a few more choices to make. First, you need to decide what kind of sealer to use. As I mentioned in the beginning, RTS or 1k could be used to save money. Why put a 1K sealer over your 2K primer (I hope you are using a 2K primer) then apply a 2K top coat? It is like the old saying, “It's only as strong as it's weakest link”. If you use a 1K sealer in this fashion it is like replacing a link in your tow chain with a nylon tie! With 2K there are a few options, epoxy and urethane being the most popular. I don't feel that there is a huge difference in the two as far as how they apply or work. Epoxy is more forgiving with sensitive substrates. It really comes down to what you feel more comfortable with. The epoxy has no isos so that would be one reason to choose it. Now that you have decided what sealer to use you have to decide on what application. Most sealers give you the option of a “wet on wet” (or very close to it) or a full “barrier coat” application. The difference being with “wet on wet” the sealer is applied and then allowed a short flash time before the basecoat or SS is applied. A “barrier coat” is where the sealer is applied, then allowed to cure or at the very least to totally flash. This allows the sealer to become a barrier so the solvents from the color coat can't penetrate it and attack the substrate.
The barrier coat procedure allows for he sealer to do MUCH more of what you choose to use a sealer for in the first place. The choice is made taking into account a few factors. How sensitive is the substrate? Or, how aggressive are the solvents in the color coat that you are applying? If it is very hot weather and you are using a slow solvent in the color coat to help it lay out, you may choose to use a sealer because you know that the substrate is sensitive and the slow solvent will attack it.
Well, that is about it for the basics, have fun!
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | OK, Martin, we're going to have to get these things made into tech tips. I don't know that I'll ever have the courage to paint my truck myself, but if I did, I'd print your instructions out and keep them right beside me while I shop for materials and while I'm spraying the paint.
Great work! | | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Glad it can be of some help guys, thanks. And Paul, I am the Wizard of OZ I will give you the courage.  Just remember, the only difference between putting a coat of wax on your truck and a show quality paint job is the time it takes to do it. If you can do the steps needed to apply a coat of wax, you can take the STEPS it takes to paint it too.
| | | | | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | Martinsr, as an old guy who has painted a few going back to a 40 sedan in 62, a 39 coupe in 68, and a 63 Dodge pu (driveway job in 78) I thank you for the updates. I will be doing my 41 sometime in the near future in a unattatched garage with an outside air supplied mask. No fear for the neighbors or my wife and dogs. Dennis | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | If any of you copied this or printed it for future refference, do it again. I had forgotten to add urethane primer! It is there now, sorry about that.
Dennis, good to hear you are prepared, be careful and have fun.
| | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Martinsr, Thanks for the info. been using it and has been a big help, works for me. printed all the info read it and go at it , again thanks Jbennett 40 burb | | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 |
'53 Chevy truck 1/2 ton
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Martain SR.Thank you for takeing the time to post this very informative article.When im done here im going to print it out and put it in my tech file.Its great to be able to go back and reread it and you put it in understandable terms.Im wondering if you could post an article on the steps involved, the tools needed and the types and grit of sandpaper one should use when preping the body for the final topcoat and at what point you should be working out dents and filling them.Im sure theres many out there like myself where are current project is our very first one.Thanks again on the exellent article...Ron
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Ron, I have posted my "Paint atomization basics" and my "Bonbo basics" here on the forum. If you can't find them I will post again. As for the "whole Enchilada", that post would be a mile long! I have been working a few more, I try to keep them zeroed in on a particular step. If I were to do the whole thing in one, your brain would be over loaded. I'll try to get another done soon. You know, my "bookmark" to this sight hasn't worked in a while, is there something wrong?
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Martin , i was haveing problems yesterday and earlyer today with the book mark.I have already copyed and filed your atomizeation and your bondo posts and apreciated your takeing the time to post both.When i took my cab in yesterday for welding the guy doimg it was telling me the 6 steps involveig primeing sanding and so onand showed mesome difernt boards and holders and such.By the time i got home it was all a blur.Maybe just a litle here and there?THANKS
