7 members (Jon G, fonz8261, MickeyP, Otto Skorzeny, 2-Ton, TexasJim50, 1 invisible), 90 guests, and 2 robots.
Topics128,132
Posts1,056,383
Members48,441
#1057067 09/18/2014 6:07 PM
Hello everyone 46 1/2 I am somewhat unclear on how much oil to add to the transmission in the manual it say's the capacity Is 1 1/2 pints it also say's when reinstalling the trans to put 1 pint in through the speedometer gear is this in addition to or part of the 1 1/2 pints you add
Thx Kevin
if the trans has been emptied/rebuilt/cleaned out, maybe put some in the speedo hole to insure it doesn't start dry, fill via the main fill/check hole until it's right up to that hole, and starts to run back out, which from dry will be roughly the measure given
