| | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello everyone 46 1/2 I am somewhat unclear on how much oil to add to the transmission in the manual it say's the capacity Is 1 1/2 pints it also say's when reinstalling the trans to put 1 pint in through the speedometer gear is this in addition to or part of the 1 1/2 pints you add
Thx Kevin
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the trans has been emptied/rebuilt/cleaned out, maybe put some in the speedo hole to insure it doesn't start dry, fill via the main fill/check hole until it's right up to that hole, and starts to run back out, which from dry will be roughly the measure given
Bill | | |
