1 members (baldeagle),
110
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Whats a excellent pipe thread sealant to use on the oil pump pick-up tube threaded end that screws into the oil pump body? Vibration and lots of hot oil present. Thanks for your expertise. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Sealant is completely unnecessary on that part. Put a couple of drops of motor oil on the threads and tighten it up firmly. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And to add to Jerry's advice, point being, you don't want any stray pieces of anything getting into the oil circuit, so stay away from RTV or Teflon anywhere inside you engine. dg
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Ditto for fuel system parts- - - -no Teflon tape on anything associated with gas lines. I've seen lots of clogged jets and flooding over a tiny piece of pipe tape. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I used pipe dope (not tape) to seal the various screw plugs on my W1. I read of some using blue Loctite but pipe dope does as good or better without sticking them to the housing. Just don't try to play little Dutch boy trying to plug the dike by using too much of it.
