3 members (1955 1 Series, Guitplayer, 1 invisible), 45 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1056924 09/18/2014 12:43 AM
Whats a excellent pipe thread sealant to use on the oil pump pick-up tube threaded end that screws into the oil pump body? Vibration and lots of hot oil present. Thanks for your expertise.
H Online: Content
Sealant is completely unnecessary on that part. Put a couple of drops of motor oil on the threads and tighten it up firmly.
ryanz #1056998 09/18/2014 12:05 PM
And to add to Jerry's advice, point being, you don't want any
stray pieces of anything getting into the oil circuit, so
stay away from RTV or Teflon anywhere inside you engine.
dg
Denny G
Sandwich, IL
H Online: Content
Ditto for fuel system parts- - - -no Teflon tape on anything associated with gas lines. I've seen lots of clogged jets and flooding over a tiny piece of pipe tape.
Ex Hall Monitor
Ex Hall Monitor
I used pipe dope (not tape) to seal the various screw plugs on my W1. I read of some using blue Loctite but pipe dope does as good or better without sticking them to the housing. Just don't try to play little Dutch boy trying to plug the dike by using too much of it.
