| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | It's always a very pleasant experience to use a tool that actually does what it is supposed to in a quality manner. I needed to re-plumb the fuel lines to the tri-carbs on my 348. I knew I needed a double flare to be safe (using brake lines). I really didn't look forward to making single flares much less doubles with my current flaring tools. I found the Mastercool 71475 double flaring tool here in Minnesota for $289 ($445 at autozone), it came highly recommended on other forums. I have to say it is worth every cent. It was a pleasure making the fuel lines, perfect each time, and so simple to do. I also purchased a bending tool, Titan, and it makes perfect bends each time ($13). I thought would share this, if you are looking for such a tool, this is a good one. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have the same tool, only under the Blue Point brand name (purchased from Snap-On). I agree, it is a great tool. With the proper adapters (I got mine in the full kit), it will also do Metric Bubble flares, as well as the different styles of push connects. With a little trickery, I have also been able to make the hybrid flare that GM and Ford has been using recently. They also have the 37 degree flare dies for doing stainless/A-N fittings.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I bought one from my Snap On dealer, and I agree the thing is great. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Awesome tool. I've owned one for a few years. Great for doing flares for repairing lines on or under the vehicle. Just used it on my neighbour's 01 Silverado for an emergency repair.
