8 members (Wally / Montana, Steelonsteel, Tronman, 1955 1 Series, Bill Hanlon, Hotrod Lincoln, LAROKE, 1 invisible), 137 guests, and 3 robots.
Topics128,201
Posts1,057,279
Members48,466
I decided to rebuild the stock front brakes instead of doing a disk kit. I'm replacing the front drums in the process. Is it really necessary to rivet the drums back to the hub? I don't see where it could possibly go.... Is there something I'm missing? Thanks
no Tim, the riveting was useful at the factory, but not at all necessary, much easier to work on the brakes with drums and hubs separate
No need to rivet the drums to the hubs. That was only done to make the drum and hub an assembly for installation at the plant. Otherwise, they serve no purpose.
Bill Burmeister
Thank you, Bills. I was hoping that would be the case.
I could be wrong but I think the factory was thinking about safety as much as assembly line ease. They even put screws to hold the rear drums on and later clips on the rear axle wheel studs to keep the rear drums from coming off in case a wheel came loose.
That said, I do not re-rivet them.
My Blog
