| | | Forums66 Topics128,164 Posts1,057,081 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | Here are the approx specs: 8 bolt holes, 0.500" in diameter each Approx. 4.700" outside diameter Approx 2.900 - 3.100" inside diameter
I cannot find any current part number anywhere. These are the thick metal gaskets (or tins) that go between the axle shaft flange and the wheel hub.
I was able to find a modern DANA gasket that I modified, but it is too thin and leaking.
1946 Chevy 2-Ton Rat Rod Wrecker
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | I have made a new development.
I believe the GM part number is 3653928. Although that still hasn't gotten me anywhere.
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I haven't used a flange gasket in years. I use silicon and it works better than gaskets ever did. The OEMs have not used gaskets in over 30 years. | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | I bought mine at Jones Vintage parts. They are a little slow in checking stock. Ask for Seal 5904s and ask them to take measurements | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | As above. I made mine from 0.5mm or .020 gasket paper and then used rtv. No problems at all.
'47 Canadian RHD 1.5 ton truck
