| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | weird....my 49 has frame holes and lower mount for front lever arm shocks and (riveted on) tubular shock rear mounts.... my truck is early 49...
would have thought it should have front and rear lever arm or at least if its going to have tube shocks it should have front and back matching.
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Check the rivets real close and see if they match the rivets elsewhere on the truck. Someone may have riveted the tube shock mounts on at a later date. I would guess it would be difficult to perfectly match a factory rivet job. Don't you love mysteries? Carl
