1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
#105641 09/26/2002 2:24 PM
I am in progress to ready the cab for painting.
The cab is sandblsted and all the rust is removed replaced corners and dents pulled out. I found that the rear panel is warped, either from sand blasting or what ever. If I push the left side out the right side pops inward and reverse.
What is the best way to shrink the panel?
1) Heat one side cool of the other with wet towel
2)???????
3)???????
If The hot cold treatment is the way to go, can any body explain to me where to heat and where to cool. Also how much heat is needed.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#105642 09/26/2002 7:34 PM
Go to search above and look for "shrinking basics" by MARTINSR.
'67 GMC 3/4 292 4spd
