8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | I am in progress to ready the cab for painting. The cab is sandblsted and all the rust is removed replaced corners and dents pulled out. I found that the rear panel is warped, either from sand blasting or what ever. If I push the left side out the right side pops inward and reverse. What is the best way to shrink the panel?
1) Heat one side cool of the other with wet towel 2)??????? 3)???????
If The hot cold treatment is the way to go, can any body explain to me where to heat and where to cool. Also how much heat is needed. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Go to search above and look for "shrinking basics" by MARTINSR.
'67 GMC 3/4 292 4spd
