8 members (GA Boy, 2-Ton, Gray_Ghost, Nick in Manitou, GMCJammer51, Joe H, Andrew_Julio, Jay R),
75
Mod | | | Forums66 Topics128,169 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 5 New Guy | | New Guy Joined: Sep 2014 Posts: 5 | i have a 1954 3800 with a bent rear axle tube. Found a late model 1949 3600 wondering if 3/4 rear end is interchangable and able to bolt right up.
| | | | | Joined: Sep 2014 Posts: 5 New Guy | | New Guy Joined: Sep 2014 Posts: 5 | i have a 1954 3800 with a bent axle tube. Found a late model 1949 3600 needing to know if a 3/4 ton rear end is interchangable and will bolt rite up.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think the 3600 used an Eaton HO52 and the 3800 used an Eaton HO72. The difference is at the outer ends. Larger backing plates and brakes. As far as the mounting pads, someone else will have to help you, my guess would be that they might be different.
Best I can offer is that the spring pads on my '50 3600 are 41.75" on center.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2014 Posts: 5 New Guy | | New Guy Joined: Sep 2014 Posts: 5 | OK thanks thats a lot of help gives me some things to look at. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | it will bolt in, but as mentioned brakes are different | | | | | Joined: Sep 2014 Posts: 5 New Guy | | New Guy Joined: Sep 2014 Posts: 5 | Ok thanks.. So would I be able to strip my rearend and use that hardware or just use the 3/4 ton setup instead. Found the complete with springs 3/4 rearend for only $200. My first Chevy so I'm alil lost with some stuff. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As I said, I can't say for sure but if the spring perches are the same spacing as Grigg seems to indicate then it might be possible to use your 3800 backing plates on the housing. In the interest of interchangeability the HO52 & 72 housing may be the same, that is the flange might be the same.
DG
| | | | | Joined: Sep 2014 Posts: 5 New Guy | | New Guy Joined: Sep 2014 Posts: 5 | Thanks again I appreciate all the advice | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | or you could have the axle tube straightened. | | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | I cant confirm for sure but my knowledge on '49 parts interchange is that rears in 49 from 3600-3900 were interchangeable. I dont have the '54 specs off hand but it should be the same.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | I would think that the rears whole would be swap-able between ea52 and 72. Have you confirmed the identity of both axels? | | |
