2 members (LAROKE, baldeagle),
63
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | where do you buy a set of clutch head bits online or at a walk in store? i am having no luck. thanks.
Get busy liv'n or get busy die'n
| | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I have been told that you can get them at NAPA parts stores but I haven't tried yet.
David
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | You can order them online from Chevy Duty. http://www.chevyduty.com/ | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Chevy duty has the best price for the 4 piece/size set. Napa wants $11.00 each!!, I know I have to buy 2 of them! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevy Duty has the 4 screwdriver set for $14.95. If you are looking for the set of driver "bits", check out NAPA (maybe someone will post a part number). Or, check Chev\'s of the 40\'s . Where is says, "Enter Search Criteria Above", type "clutch head". They have 5 bits and sell them as pieces or as a set ($19.00). Tim | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Sometimes you can get them for good prices in big bit sets. That is how I found all three sets I have, although I did have to go to NAPA for the biggest one. They're cheap bits, but I have never had any trouble with them. If you aren't in a hurry, look around a bit (no pun intended). | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I bought 1 clutch head bit at the local Ace Hardware store. This Ace is an exception though, as it is the size of a supermarket... and has so much stuff, sometimes it is in the floor and you have to walk around it. -W | | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | I saw them in the tool department at Sears last week. The price was about the same as NAPA. | | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 |
