5 members (frogfarmer, baldeagle, Brian Moore, Hotrod Lincoln, 1 invisible), 29 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#1056204 09/15/2014 2:05 AM
Ok this for those who know way more about paint than i do. Can you put self etching primer over parts of the sheet metal that still have some paint left behind after sanding. Yes i am using a rattle can for now.
Joe
Self etching primer has no advantage on steel.
It is absolutely necessary for aluminum, stainless and galvanized.
Regular primer will hold on cleaned steel or cleaned sanded paint every bit as well as self etching.
Barely cleaned (remove dirt,oil and loose rust) rusty steel does best with a rusty metal primer.
Did not know that, thank you Jim
I agree with Jim 100%. Etching primer is the most misused
product on the market.
It's meant to give tooth to a surface that is difficult to bond
to. Sandblasted or sanded steel doesn't need etching primer.
It was originally formulated to aid in the bonding of paint to
the galvanized rocker panels that were introduced a few decades
ago.
DG
Denny G
Sandwich, IL
When I installed new stake pockets and had to do some fab work,I sprayed rusto etching primer and it flash rusted in no time even tho it is under cover. I will be using epoxy primer for the exterior now.
None of the normal primers are weather resistant. They are Primers.
However a final coat of Primer Sealer if you are not going to top coat right away, will be rust free in dry storage for a year or more and in mild weather for months
PPG DP90L only on fender 6 years ago and no primer under the
paint on the boards 7 years ago. I'll get around to painting
it one day, if,,,,,I live long enough!
Truck is used on regular basis, I avoid rain when possible and
never driven in snow/slush.
http://www.pbase.com/dennygraham/image/156702149
DG
Denny G
Sandwich, IL
