1 members (frogfarmer), 116 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#1055897 09/13/2014 4:04 PM
I need to put my gas tank between the frame rails behind my rearof my 46 1/2 ton anyone have any idea what gas tank to use?
The mounts are more important than the tank.
My G506 has two mounts that bolt to the frame rail and supports a 40 gallon tank.
One of the parts trucks I bought had nothing more than a tank held on with metal straps. I would say it was a 15 gallon tank.
40 gallons of fuel is roughly 350lbs and about $150 to fill.
Summit should have all sorts of fuel tanks.. just make sure you fab a solid mount.
ok, thanks for the tip
