1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Back in April I ordered wiper motor and arm from LMC. They did not have the arms after weeks of waiting I finally found the arms at Dreamers (rods and pickups). Finally months later I get around to the install. I unpack everything and find that the arms where they attach to the motor has like a octagon shape grommet and the motor has a plastic grommet (round) on each short shaft where the arms attach?? If I remove the grommets from the shaft the octagon shape will go over and fit on the shaft.then the transmission retainer clip and gasket will fit back on. question ? do I have the wrong wiper arms?? does the grommet supposed to be removed from the shaft?? Anyone experience this? of course LMC has no tech. advise and dreamers are looking into it and is going to call me back. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Dreamers is a great place, it is just down the street from my house, they actually build cars in their shop. So they really do know what they are talking about. Not to mention they are some of the nicest people you would ever meet. But they have the same problems we do with the repro parts.
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | they got back to me and gave me a solution. my next question is Is there anywhere I can find an assembly pic or instruction sheet to put the arms, motor, and all parts together? | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I have a wiper connecting rod and a wiper control nob ? are these pieces needed on the electric wiper system? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I replaced the arms and wipers on my truck with a set I bought from a marine supply store. They also fit on an MGB. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a wiper connecting rod and a wiper control nob ? are these pieces needed on the electric wiper system? ...link... If its the parts in the link above you won't need them with an electric wiper motor | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I have a wiper connecting rod and a wiper control nob ? are these pieces needed on the electric wiper system? ...link... If its the parts in the link above you won't need them with an electric wiper motor yes and thanks !!! | | | | | Joined: Apr 2015 Posts: 3 New Guy | | New Guy Joined: Apr 2015 Posts: 3 | So, what was their solution to the arms fitting on the motor? | | |
