2 members (Barney1951, ronsway),
60
0
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | On my newly acquired 61 apache the previous owner installed a new master cylinder but never bled the brakes. I bled all the brakes and adjusted all the brakes till they started to grab a little. (I already dismantled the brakes and freed up the rusted adjusters and lubed the backing plates.)When I apply the brakes the right rear tire skids. When I spin the wheels when they are off the ground they all seem to have equal grab. Any suggestions? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Check for brake fluid or rear end grease on the brake shoes of the wheel that locks up. Grease-soaked brakes from a leaky axle seal are notorious for locking up a wheel, particularly on gravel of slippery pavement. There is no way to remove grease from brake linings- - - -replace 'em! Jerry
| | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Jerry, thank you for the suggestions. The rear shoes are clean. The right front had a leaky wheel cylinder and brake fluid soaked shoes. I rebuilt the wheel cylinder and repaced the front shoes. The right rear wheel is locking up on asphalt pavement. Do you think maybe only one of the pistons in the right rear wheel cylinder maybe working and pushing out one shoe exstensively? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | One working brake shoe would probably not have enough stopping force to lock up a wheel. If there is any doubt at all about the proper operation of the brake, either rebuild or replace the wheel cylinder(s) and brake shoes, plus springs and hardware. Trying to do a partial brake job is sort of like drawing to an inside straight in a high-stakes poker game. Good brake work is pretty cheap life insurance.
I just spent a little over $250.00 on parts alone, rebuilding the front brakes on a 92 Dodge Dakota, and I don't regret it at all. I won't be hiring a lawyer to defend me from a multi-million dollar lawsuit if a kid runs in front of me while chasing a ball. Jerry
| | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Jerry, good advice. I took the right rear drum off and found that the wheel cylinder is pushing out both pistons. I sanded the shoes and the drum and re-bled the rear brakes. I am still not 100% happy with the stopping power but it does not appear to be locking up anymore. I will keep you posted. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Just a thought, If the other rear wheel has a stuck wheel cylinder then the effective brake pressure would force one wheel to do all the braking. That one would lock up while the other one was still turning. And, while I am speculating...if the new MC is a dual MC and it is plumbed 1 and 3 you will get uneven braking. I would pull the other side apart and have a look. Dual MC has two circuits. Front, and Back. Follow the brake lines and it will be clear.Just like Hotrod said, brakes are your life.
Steve H
| | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | The master cylinder has only one chamber but it feeds both the brakes and the slave clutch valve. I will take a look at the left rear tomorrow. Thanks | | |
