6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#1055656 09/12/2014 1:31 PM
Will the rear axle from a 1965 1/2ton C10 fit ok under my 1958 1/2ton GMC truck? What about the rear axle from a 1983 1/2ton Chevy truck? Thinking my original rear axle wont handle the drivetrain upgrade-putting a 350 w auto trans in my truck.
Thanks in advance
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
dtwbcs #1055665 09/12/2014 2:25 PM
a V8 was an option in '58, if the rear end under your truck is sound it'll handle it as well as any other rear end if you don't abuse it .... if you insist on changing it out, get a tape measure and see if it'll "fit OK" and check whether you can hook up the e-brake
dtwbcs #1055712 09/12/2014 7:01 PM
I have been running a 3.07 Spicer from a '59 GMC behind the 350 in my '56 for years.
dtwbcs #1055731 09/12/2014 9:32 PM
No , I don't want to do any extra unnecessary stuff to the truck while I am transforming it .
so thankyou
Danny
dtwbcs #1055735 09/12/2014 9:50 PM
The 65 truck has rear coil springs and all the related suspension attachments welded to the housing. Those would have to be removed and new spring perches welded to match your 58.
You would probably have to do some surgery on the later rear axle as well providing it isn't too wide.
I have been running a 350 in my 56 with a 3sp OD trans and the stock 390 rear end since 2000. I don't think you can break the stock rear end with that combination, the main problem is that it is probably geared too low for suitable highway driving. A better ratio rear end or an overdrive of some type would definitely help.
Fred
dtwbcs #1055743 09/12/2014 10:34 PM
Done this before; here it is again (or reason not to worry):
"Let's see, we take out an old engine that puts out maybe 250 lb. ft. torque, backed by a granny tranny with a 7.0 low gear, and replace it with a V8 with, say, 400 lb. ft. torque and an auto tranny with a 2.5 low gear.
250 x 7.0 = 1750 lb. ft. torque to the rear versus 400 x 2.5 = 1000 lb. ft. torque to the rear.
And how come nobody worries about the driveshaft and U-joint as well as the rear end?
Just sayin'!"
dtwbcs #1055998 09/14/2014 12:37 AM
Thanks 4 the advice.I will use what I have
Danny
Woodswarrior #1056038 09/14/2014 3:26 AM
Just sayin'!"
Great post Woody!
