| | | Forums66 Topics128,082 Posts1,056,324 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm not too sure I'm putting my pedal assembly together correctly. This would be for a '54. Can someone point me to a picture or description of what goes where? Thanks.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I found a picture here:http://chevy.oldcarmanualproject.com/manuals/47asit/47asit25.html
I would guess it goes together first putting on a spacer, clutch pedal, spacer, then the spring between the 2 cups, and finally the securing clip.
Seems odd that the clutch pedal does not have a grease fitting like the brake pedal.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Seems odd that the clutch pedal does not have a grease fitting like the brake pedal.
Dennis It seemed odd to me at first as well. I quickly realized that the flat on the pivot shaft allows grease to "travel" the entire length of the shaft thereby lubricating both brake and clutch arms/pivots. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Oh, OK. Then I must be wrong about one of the spacers going between the pedals. They must go on the outboard of the 2 pedals?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | The spacers go around the brake pedal. The flat on the shaft does not go all the way to the bracket so can't go between the bracket and the clutch pedal. Found excellent pictures of it on DADS50 photos. There was even a schematic! At least this is now updated in case someone runs across it.
Dennis
40 Chevy 1/2 ton
