Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, 55shaker, Ribside), 128 guests, and 5 robots.
Topics128,281
Posts1,058,478
Members48,490
#105549 07/25/2002 10:38 PM
Has anyone used the rustolem appliance epoxy for the inside fenders? Or what are you using?
#105550 07/26/2002 3:18 AM
I plan on using a truck bed coating made by duplicolor you apply with a special roller . I already did the underside and inside of the cab and the underside of the running boards . I may even put two coats on the rear fenders because the are fiberglass and hopefully it will prevent rock starbursts .
