2 members (klhansen, 1 invisible),
88
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10553 11/12/2002 11:34 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | What is the inside diameter of a 216 intake manifold where it bolts to the head? Same question for a 235. I would like to be able to identify which is which. I also wonder about the performance of a 2 carb 216 manifold on a 261. Who has some experience and/or opinion. | | |
#10554 11/13/2002 12:35 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 216 has an 1-1/4 opening and the 235/261 has an 1-1/2, I believe. Anyway, the 235/261 is bigger. You could ream the 2- carber 216 manifold out if there is enough meat on the casting, since the engines all have the same bore spacing on the manifolds.
#10555 11/13/2002 12:50 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | The 216 dual intake will work fine on 235's or 261's. You will need to buy the intake rings(?) for the 235 or 261 and take it all to a machinist to have him machine it to size. Cost shouldn't run over $20-$30.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#10556 11/15/2002 3:51 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Thanks Guys Appreciate the help. | | |
