| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | All my turn signal wires are soldered and ready to use shrink tubing. But since they are bunched up kinda close how do I keep them separated while doing this operation? Would a sheet of aluminum work? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a piece of paper should work, although it shouldn't be a problem if your 'heat gun' doesn't shoot flames  with a number of wires close together you might even be able to shrink the covers all at the same time if you can keep a number of pieces properly positioned long enough, they won't 'melt' together but the proper way to make up a connection like that is to stagger the wire lengths so no joints are in exactly the same place - or find a connector with the right number of pins and solder the wires into male and female plugs Bill | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | I use a 3 or 4 inch wide putty knife for a shield, held behind the wires. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I like this idea 'cause it stays in place. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | That worked really well. Thanks, Steve | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Red58 is right on the mark for staggering the splices, it eliminates any possibility of bulging the harness, keeps it neat and professional looking 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
