| | | Forums66 Topics128,043 Posts1,055,614 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Got the window regulator repair part from Carter today (the crank where the handle attaches). Putting in the new gear, would you suggest putting any grease or lubricant in there before putting it back together?
The old part contained some oil, but mostly dirt.
Thanks for the advice - Bruce | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, I'd pack it up with a light grease. Just about any would do, I would use a light chassis grease. I'd stay away from a heavy fiber grease like that used for axle bearings, that's getting really hard to find but you may have some on your shelf. Have used Lubricate in the past but I've found that it dries out over time. Oil isn't going to stay in there very long and this will probably be the only time it will ever be lubricated.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lubricate or Lubriplate, Denny? I had not heard/read that name in many years. Which of their products would you recommend (if that is what you referred-to)? | | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | I use white grease lube on mine. | | |
