6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#1053745 09/03/2014 12:09 PM
Can anyone confirm that the threaded hole where the throttle linkage stud screws in the block is 5/16-18? This is in my '55 235. I need to fab up a replacement and don't want to take the time to pull it out just to check the thread since it's my daily driver. I figure someone on here should know.
Denny G
Sandwich, IL
Thanks Denny, I knew someone would know. I'm looking through the album you posted, I like the drawing of the stud. TooMany2count was nice enough to offer me a used one by PM.
Thanks to TooMany2count, who mailed me a stud, I was able to rebuild my throttle linkages on Saturday. His showed up Friday in the mail. Saturday morning I went to town with the new stud in hand to find a clip for it. The one on my truck never had a clip which I think lead to some of my problems. Here's what my stud looked like when I removed it.
Old Stud
I found that a 3/8 e-clip fits perfectly on the new stud. I also found a 3/8 id bronze bushing that I thought I might use on it as well. The holes in my bell crank were oblong and oversized already so I drill them out to 1/2" to fit the bronze bushing.
You can also see that I welded some washers on both sides of the arms of the bell crank. Those holes were oblong as well. The 1/4" rods were worn so they got a little weld and then ground back down to round.
Once installed I added a few washers to take up the space you can see here.
Everything moves smoothly now. If I do anything else it may be to make new linkage rods using heim joints.
I have more zippers then a pair of cargo pants
yahoo thumbs_up glad to help you out & that it worked for you....joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Looks good! Where did you get the bronze bushing?
My Blog
The bronze bushing came from Ace hardware. It's 3/8 ID, 1/2" OD, didn't measure the shoulder or length.
Good Job Chad, very professional looking. Should serve you till
they won't issue you a licence any more or till we run out of
crude for gasoline.
DG
Denny G
Sandwich, IL
Denny, that's was my intention. I wanted to fix it so it wouldn't wear out again. That's why I may go back with heim joint ends on new rods.
Sweet fix! Much easier than my fix which involved a short pipe tig welded in where your bushing is. Looks to me that you could have re-used your old stud with that fix, since the bushing won't ride on the bad spot anymore. But then, I am a tight wad. Now all you need to do is add a grease fitting and you will be good until the solar-powered hover crafts come out.
Carl
Me too, in the past if I couldn't find one I would have brazed it up & filed it down to fit the bushing...joe
~ Joe
I didn't even consider that I could have used the old one. I was looking to use a shoulder bolt until I was offered that good one.
If I were you, I would save the old one. You never know... I usually put parts like that in a place that I know I will find it in the future, and then never see it again. Don't put it there. smile
Carl
I've got a plastic storage tub with everything I've pulled off that may be use-able. That old stud is going in there. Hopefully I'll remember I have it if I need it.
I have about four different sizes/colors of those plastic tubs, dating back to around 1969. You will soon forget what you put in those bins/tubs, but it is comforting having them AND you sometimes find something useful (even if the use is not the original use).
