10 members (JW51, 68ironhead, baldeagle, Guitplayer, 2-Ton, walter74, Eisenholtz, Peggy M, joe apple, WICruiser),
82
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Can anyone confirm that the threaded hole where the throttle linkage stud screws in the block is 5/16-18? This is in my '55 235. I need to fab up a replacement and don't want to take the time to pull it out just to check the thread since it's my daily driver. I figure someone on here should know. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Thanks Denny, I knew someone would know. I'm looking through the album you posted, I like the drawing of the stud. TooMany2count was nice enough to offer me a used one by PM. | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Thanks to TooMany2count, who mailed me a stud, I was able to rebuild my throttle linkages on Saturday. His showed up Friday in the mail. Saturday morning I went to town with the new stud in hand to find a clip for it. The one on my truck never had a clip which I think lead to some of my problems. Here's what my stud looked like when I removed it. Old Stud I found that a 3/8 e-clip fits perfectly on the new stud. I also found a 3/8 id bronze bushing that I thought I might use on it as well. The holes in my bell crank were oblong and oversized already so I drill them out to 1/2" to fit the bronze bushing. You can also see that I welded some washers on both sides of the arms of the bell crank. Those holes were oblong as well. The 1/4" rods were worn so they got a little weld and then ground back down to round. Once installed I added a few washers to take up the space you can see here. Everything moves smoothly now. If I do anything else it may be to make new linkage rods using heim joints. | | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 |  glad to help you out & that it worked for you....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Looks good! Where did you get the bronze bushing?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | The bronze bushing came from Ace hardware. It's 3/8 ID, 1/2" OD, didn't measure the shoulder or length. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Good Job Chad, very professional looking. Should serve you till they won't issue you a licence any more or till we run out of crude for gasoline.
DG
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Denny, that's was my intention. I wanted to fix it so it wouldn't wear out again. That's why I may go back with heim joint ends on new rods. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Sweet fix! Much easier than my fix which involved a short pipe tig welded in where your bushing is. Looks to me that you could have re-used your old stud with that fix, since the bushing won't ride on the bad spot anymore. But then, I am a tight wad. Now all you need to do is add a grease fitting and you will be good until the solar-powered hover crafts come out. Carl
| | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 | . Looks to me that you could have re-used your old stud with that fix, since the bushing won't ride on the bad spot anymore. But then, I am a tight wad. Me too, in the past if I couldn't find one I would have brazed it up & filed it down to fit the bushing...joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | I didn't even consider that I could have used the old one. I was looking to use a shoulder bolt until I was offered that good one. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I didn't even consider that I could have used the old one. I was looking to use a shoulder bolt until I was offered that good one. If I were you, I would save the old one. You never know... I usually put parts like that in a place that I know I will find it in the future, and then never see it again. Don't put it there.  Carl
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | I've got a plastic storage tub with everything I've pulled off that may be use-able. That old stud is going in there. Hopefully I'll remember I have it if I need it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have about four different sizes/colors of those plastic tubs, dating back to around 1969. You will soon forget what you put in those bins/tubs, but it is comforting having them AND you sometimes find something useful (even if the use is not the original use).
