| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | 1941 Chevy 1.5 ton , it has a 12v coil and iam running a 6v battery, will it need the 6v coil and will I eventually burn the 12v coil up ????? It's been had to crank lately | | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | You're lucky it runs at all. The coil won't burn out- - - -it will just have a very weak spark. There's too much resistance in the primary coil winding to flow enough current to induce a good high voltage spark. Buy the right coil- - - -don't send a boy to do a man's job! Jerry
